Adjustable Dual Power supply ckt needed.
MAXPAYNE
Member level 5
Member level 5
BD
power supply ckt
I need a adjustable dual Power supply 0--->>+/-30v ckt as I am gonna build my bench supply. Please post a ckt if u have. But don't post ckt containing LM337 as I didn't find it here. Thanks in advance....
dindeds
Full Member level 2
Full Member level 2
There's not only lm337 can be used, lm338, lm350,lt/lm1083/4/5 etc should be ok..
2nd source from other manufacturer too..
zawminoo
Full Member level 1
Hi
I think that LM317 can do this.
LM317 can got more easier than LM338.
But LM317 can use 1.5A(max).
For 4A, use LM350 and for 8A use LM338.
MAXPAYNE
Member level 5
Member level 5
BD
Hi dindeds, Thnks ...
My trnsfrmr is center tapped (24V-0v-24V). can i use uor ckt ?
Added after 51 minutes:
Also where is the controll pot location ???
IanP
Advanced Member level 7
West Coast
If your transformer doesn't have isolated windings but one common centre tap you can use just one bridge, as shown in the attached picture ..
Replace 2.2kΩ fixed resistors with 5kΩ potentiometers .. this will make both output (independently) adjustable ..
Regards,
IanP
MAXPAYNE
Member level 5
Member level 5
BD
IanP, uor attached sypply isn't variable which I need..!!
Added after 1 minutes:
Is it possible to make it variable ?
Awarapunshee
Advanced Member level 1
Some Where In Heaven
You can make that variable by putting a variable resister between the center pin (GND) and ground and put another resistor of 220 ohm between center and output pin. But remember the min voltage will be the regulator output voltage i.e if you use 7805, min voltage will be 5V.
Regards
K.R
Hello
check this circuit
MAXPAYNE
Member level 5
Member level 5
BD
Thnks but I don't able to manage LM337 as I wrote in my first post here....
dindeds
Full Member level 2
Full Member level 2
Take note, the regulator ICs I mentioned above are +ve regulator type.
It,s best to use split 24V trafo (most Toroidal type hv) windings if you're not familiar with using single CT type. By using suitable pot in the Adj. pin you can vary the o/p voltage up to +/- 30V.
