ForteRock
Newbie level 3
Hello all,
I'm an undergrad college student taking an advanced digital system design for FPGAs course. We're using the same Nexys3 board a previous course used, but this time around I can't program the actual board.
The .bit file itself is fine, but anytime I open up Adept I see this,
![Adept.PNG Adept.PNG](https://www.edaboard.com/data/attachments/55/55224-33c375b82aec9665eac3e766b0430619.jpg)
so I can't exactly get it onto the board.
I've tried re-downloading, older versions, moving computers - nada. The only other thread about this I could find as solved when someone fixed the pins on J8 and I think mine are set up correctly. Column M0 is covered, M1 uncovered.
The board's LED tells me everything is passing, though it could be half truthing. I don't have access to another board so I can't really check if it's the board is failing.
Can anyone help with this? Is there another software I can use with this board?
Many thanks,
- Forte
Many thanks,
- Forte
