Adding a source file of C language in MPLAB
kfet
Newbie level 1
.c file in MPLAB
I'm using MPLAB to write programs for my PIC1330. Normally I write assembly code but now I want to do this in C. But when I make a Project I can't put a .c file in my source file. The .c file comes in other files, so if I compile I get 'Build aborted. The project contains no source files.'.
Can anyone help me?
Slorn
Junior Member level 2
Belgium
Re: .c file in MPLAB
Hi
This tutorial explains how to install MPLAB and the C18 compiler and then helps you make a first project.
Slorn
ceciliapl
Newbie level 1
madrid
I have the same problem that you had. Have you been able to resolve it?
Thank you in advance.
Raju C
Member level 2
Bangalore
after installing C compiler . have you checked language suite ??some time it will not simulate due to this also
miredox
Member level 4
Have a look at the link that Slorn has provided. It explains clearly how to setup a c-based project in MPLAB.
baduR
right click on the mplab editor window and click on add to project.then save the project.you'll be fine
