ADC sensing code needed using pic16f676\16f72
just move some configuration bits in the ADCON0 and ADCON1 registers and ADC will work.
i am new in microcontroller...
pl give some ie. in asm lang.
What is the method you want to use to read the ADC ?
What channel are you using ?
Do you want an interruption when the ADC reading is ready ?
Do you want to read the value in a periodic time based ?
How do you want the Vref to be set ?
etc.
Depending on the needs is how do you set you system. You need to try to write you own code and post any problem you have, that way you will learn.
