rudie
Junior Member level 3
Hello guys,
I am making a circuit to measure a temperature(pt1000) with some accuracy. The circuit i made works. It has an accuracy of 0.25 degrees. The circuit also needs a supply voltage, but i can find a voltage regulator that as a great accuracy.
I want a 5V supply. But if i look on the internet i can find some voltage regulators that have a line regulation of 0.01% that is good enough because the maximum difference in output would than be: 5*1.0001=5.0005. But is that the only parameter that determines the accuracy of a voltage regulator. I guess not, but which ones are also important? Or is there an other way to make the supply voltage to the pt1000 very accurate. It would be nice if this could be done with an accuracy of approximately 1mV.
i hope that someone can help me
greets rudie
greets rudie
