1.i have internal memory in my design which is filled in with the data from the external memory.....this process is done in an always block
2.after filling in the internal memory with data..... there is an another always block which will be refreshing the internal memory ......i.e the data written internally will be overwriiten with new data after manipulation.......
3.the second always block will be intialized only after the first always block fills the data ...
4.Is this method correct will i be facing any problem with this... in synthesizing or some other back end processing....
