dxpwny
I've been playing around with various means of controlling fan speed. The fan is a 'typical' 20 inch window fan with 3 speeds.
I have a variac and like the ability of that to control the fan speed.
I've tried a fan speed controller that I'm pretty sure uses a triac. That causes the fan to emit a humming noise.
I know the key difference between a variac and triac is that a variac limits the amplitude of the AC signal, where as a triac limits a portion of each cycle of the AC signal.
With the triac control, is there anything that can be done to reduce the humming ?
I've thought of building a ciruit that detected the zero crossing point in the AC voltage. Then using that to shut off the AC for a variable number of full cycles. Is that type oc circuit reasonable ?
I'm not at all sure of the fan type / motor circuit.
