[SOLVED] About timer and counter
erwin4838
Member level 1
Tangerang-indonesia
dear all my friend
i have a sample source code in BASCOM,this fungtion only for on/off
$regfile = "attiny2313.dat"
$crystal = 1000000
Ddrb = &B11111111              'output
Ddrd = &B00000000              'input
Portd = &B11111111             'pull up
Do
If Pind.5 = 0 Then
Portb = &B11111111
End If
If Pind.2 = 0 Then
Portb = &B00000000
End If
Loop
please guide me to change this source code,for the fungtion :
portb is active after wait 3 sec,and then portb is inactive after pind.5 NC(Normaly Close) repeat in 7 times
thanks for u attention:smile:
So, we don't need second switch to turn it off, right? Try this
Code Basic4GL - [expand]
8
9
10
11
12
13
14
$crystal = 1000000
Dim X As Byte
For X = 1 To 7
Do
Loop Until Pind.5 = 0             'wait till key is pressed
Do
Loop Until Pind.5 = 1             'wait till key is released
Wait 3
Portb = &B00000000             'portb will be off after 3 seconds the key is released
Next X
Yes,don't have second switch
ok i'll try,thks
sory sir it doesn't work,this code fungtion only for active portd,just that,
i need in the first time power on,portb is inactive until 3 second,and then active
an then when pind.5 is counting 7 times then portb is inactive
please guide me:sad:
After waiting for 3 second, portd will be active.
Then if key has been pressed 7 times, portd will be inactive.
Is it right?
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
$crystal = 1000000
Dim X As Byte
Portb = &B00000000  'portb inactive
Wait 3
Portb = &B11111111  'portb active
For X = 1 To 7
Do
Waitms 50                'small delay to reduce bounce effect when key is pressed
Do
Waitms 50                'small delay to reduce bounce effect when key is released
Next X
Portb = &B00000000   'after 7 times, turn portb off.
It still doesn't work,this fungtion :
in start portb is direct active,not waiting 3sec,and then if i press pind.5 times portb is direct off,not count after 7times
hi erwin,
could you please explain you what you exactly want to do???
give me your project idea...
Have you checked your hardware? F = 1 MHz? Or you tried it at simulation software?
Maybe you need more debouncing time. try waitms with larger value.
Your RIGHT SIR,this is the final source code :
$crystal = 11059200                                          'this value 0% nothing efect for a timer
Dim X As Byte
Wait 3
For X = 1 To 7
Do
Waitms 200                                                       'small delay to reduce bounce effect when key is pressed
Do
Waitms 200                                                       'small delay to reduce bounce effect when key is released
Next X
Return                                                              'for back to timer (wait 3)
THANKS ALOT SIR,YOUR ARE MY BEST TEACHER:-D
