about low noise pmos buffer design
memsgg
Member level 1
cambridge, UK
I plan to design a low noise pmos buffer, which need large input and output swing rang, I have two topologies, can any one tell me which one is better? or any other topology is better than these two? Many thanks
1. I have a 5uA current already in my design, can I use 10X current mirror to bias the buffer? Is 50uA for bias buffer too low? How can I know how much buffer bias current is good?
2. can I use the topology (b)? just use a resistor to get the current? I think it may be not stable and may have more noise, is it?
Many thanks
Yong
hi yong!
eventually you have to replace that ideal current source. either use a resistor or a diode connected transistor. it should act as a resistor. put an nmos and tie its drain to the gate. not unless you are not going to do the full layout?
- al
    memsgg
Do you mean I should choose the topology b? Can you please give me more explaination?
Yes I will do the full layout. I have a 5uA current already in the layout.
Thanks a lot.
