bosskardo
Junior Member level 2
Hi
I came across a H-Bridge FET Driver design where both high side outputs were set high (both high side inputs connect to the same microcontroller pin) when the motor was run in either side. The direction and speed was controlled by giving a PWM to low side input corresponding to the direction.
Why would both high side outputs be set high together, is there a benefit to this?
Thanks
Thanks
