T
treez
Please advise if the SMBJ48A TVS (datasheet below) will be able to quench the attached ringing waveform, which we see on the input voltage rail of our LED driver board, whenever it is “hot-plugged” into the 48V PSU.
So, the waveform you see (attached) occurs when the 48V external power supply is “hot-plugged” to the LED driver PCB…..as you can see, the 48V rail rings up to 71.6V, and this ringing is due to thte 1uH of inductance of the supply cable which connects the 48V PSU to the LED driver PCB.
We must be sure that the input rail does not ring up above 60V. Do you think the SMBJ48A can do this? If it can do this, how many times would you say it can successfully “quench” this transient before it blows up?
SMBJ48A TVS datasheet:
https://www.fairchildsemi.com/ds/SM/SMBJ48A.pdf
