umairsiddiqui
Full Member level 2
According Virtex 5 User Guide (ug190.pdf):
Each slice has an F8MUX. F8MUX combines the outputs of F7AMUX and F7BMUX to form a combinatorial function up to 27 inputs (or a 16:1 MUX). Only one 16:1 MUX can be implemented in a slice, as shown in Figure 5-23.
Now I code
module mux16
input clk,
input [3] sel,
input [15] in,
output reg q
always @(posedge clk) begin
case (sel)
4'd0 : q <= in[0 ];
4'd1 : q <= in[1 ];
4'd2 : q <= in[2 ];
4'd3 : q <= in[3 ];
4'd4 : q <= in[4 ];
4'd5 : q <= in[5 ];
4'd6 : q <= in[6 ];
4'd7 : q <= in[7 ];
4'd8 : q <= in[8 ];
4'd9 : q <= in[9 ];
4'd10 : q <= in[10];
4'd11 : q <= in[11];
4'd12 : q <= in[12];
4'd13 : q <= in[13];
4'd14 : q <= in[14];
4'd15 : q <= in[15];
default: q <= 1'b0;
endcase
end
endmodule
I'm getting following result using Xilinx ISE 9.2.02i (IO buffers are not required) => 6 slices
and also notice there is no F8MUX!
* Final Report *
Final Results
RTL Top Level Output File Name : mux16.ngr
Output Format : NGC
Optimization Goal : Area
Keep Hierarchy : NO
Design Statistics
# IOs : 22
Cell Usage :
# BELS : 7
# LUT3 : 1
# LUT6 : 4
# MUXF7 : 2
# FlipFlops/Latches : 1
# FD : 1
Device utilization summary:
Selected Device : 5vlx220tff1738-2
Slice Logic Utilization:
Number of Slice Registers: 1 out of 138240 0%
Number of Slice LUTs: 5 out of 138240 0%
Number used as Logic: 5 out of 138240 0%
Slice Logic Distribution:
Number of Bit Slices used: 6
Number with an unused Flip Flop 5 out of 6 83%
Number with an unused LUT: 1 out of 6 16%
Number of fully used Bit Slices: 0 out of 6 0%
Number of unique control sets: 1
IO Utilization:
Number of IOs: 22
Number of bonded IOBs: 0 out of 680 0%
Problem is that I need to make a arbiter handling 64 requesters @ 250 Mhz. I was estimating that 64 bit 64:1 (with registered intermediate stages) should take 64*5=320 slices. I've not yet started coding...but it seems useless
Added after 1 hours 6 minutes:
lut packing is performed after "map"...
Design Summary
Number of errors: 0
Number of warnings: 2
Number of Slice LUTs: 5 out of 138,240 1%
Number used as logic: 5 out of 138,240 1%
Number using O6 output only: 5
Number of occupied Slices: 2 out of 34,560 1%
Number of LUT Flip Flop pairs used: 5
Number with an unused Flip Flop: 5 out of 5 100%
Number with an unused LUT: 0 out of 5 0%
Number of fully used LUT-FF pairs: 0 out of 5 0%
Added after 16 minutes:
Area & timing requirement is strict...please tell me whether it is a acheiveable target (64 bit 64:1 mux struct @ 250Mhz) or not..I'm getting skeptical...
Now I code
module mux16
input clk,
input [3] sel,
input [15] in,
output reg q
case (sel)
4'd0 : q <= in[0 ];
4'd1 : q <= in[1 ];
4'd2 : q <= in[2 ];
4'd3 : q <= in[3 ];
4'd4 : q <= in[4 ];
4'd5 : q <= in[5 ];
4'd6 : q <= in[6 ];
4'd7 : q <= in[7 ];
4'd8 : q <= in[8 ];
4'd9 : q <= in[9 ];
default: q <= 1'b0;
endcase
end
endmodule
* Final Report *
Final Results
Output Format : NGC
Keep Hierarchy : NO
Design Statistics
# IOs : 22
Cell Usage :
# BELS : 7
# LUT3 : 1
# LUT6 : 4
# MUXF7 : 2
# FD : 1
IO Utilization:
Number of IOs: 22
Design Summary
Number of errors: 0
