Re: Simple differential pair gain and phase response question
You are right. Forgot to mention which topology.
The two-stage amplifier that I am talking about is the typical two-stage amplifier, where the input stage is a PMOS differential to single-end amplifier with mille compensation. It is the typical 2-stage amplifier that we see for example in Allen's book.
The circuit that I am referring to is the following:
I have measured the differential gain between the output and the input and I got the above plot.
The thing that I am not understanding is why are we seeing a zero? Does anyone tried to do this and saw the same effect? Where is this zero coming from?
1, could you post a real graph with scaling as LvW mentioned?
2, could you show how is your testbenck looks like and how you calculate the plotted curves?
3, could you post an other graph where you just calculate this: dB20(VF("/Vout"))?
...."we are seeing a zero"? Who is "we"? I cannot see any zero.
Perhaps it is helpful to explain your understanding of a "zero".
* A zero in the p-n diagram, or
* Magnitude with 0 dB?
* Magnitude with an absolute zwero (impossible)
* Zero phase shift?
