A,B,C is 8bit integer,Z=A*B,Z=A*B+C,pls compare the delay difference between two designs,in unit of gate(e.g.:the difference is 4 Full Adder + 1 MUXs)
pls explain the result in detail
Thank you!
The area saving methord may different just in a level of 3->2 Wallace tree(the name may wrong). The MUL design is usually booth encoding + wallace tree + a final adder. You can search more info on MUL design to know more about it.
