A practical question of basic EM: E-field H-field
costox
Full Member level 4
(For example if I use HFSS): After simulation, I obtain
rE_Phi (real+imag) and rE_Theta (real+imag).
(they are Electric field in the far field).
How do I convert them to rH_Phi and rH_Theta ?
Can I convert each complex values to Mag+Angle, then add 90 to the angle ?
Thank you so much.
rrumpf
Full Member level 5
El Paso, TX
You will need to compute H from E using Maxwell's equations. The curl equation is
Δ×E=-jωµH
Assuming your far-field is of a plane wave form
E = E0 * exp(-i*k*z)
then your H-field will be
H = (Ex*ay - Ey*ax)/η
Here ax and ay are unit vectors in the x and y directions. η is the impedance of the far-field medium, and Ex and Ey are components of the electric field. Assuming this wave was travelling in the z-direction, the E field has only has x and y components.
Another approach is to simply realize the magnitude of the H field can be computed from the magnitude of the E field through the impedance of the far field medium.
|H| = |E|/η
The direction of the vector of H can be found through the Poynting vector. This says E and H are normal to each other and the direction of the field is propagating (P). They form a "right handed" system.
E×H=P
I should mention the phase of E and H are the same.
Hope this helps!!
-Tip
