em_voyageur
Newbie
Currently, the E-field I exported from CST is in Abs or magnitude of the field. How do I set CST so that I get the E-field in real and imag parts instead of the magnitude? (It's also not clear to me how to export the phase as a function of theta and phi. To give you some context, this is how columns are arranged in the text file I exported:
Theta [deg.] Phi [deg.] Abs(E )[dB(V/m)] Abs(Cross)[dB(V/m)] Phase(Cross)[deg.] Abs(Copol)[dB(V/m)] Phase(Copol)[deg.] Ax.Ratio[dB ] )
