[SOLVED] 8051 blinking led for 5 seconds and turn on led by switch
bagusdj
Member level 3
Hi guys, i want to ask about programming my at89s52 using Keil c51 with clock frequency 11.0592MHz
the idea is to interface led so it will blink for 5 second,and then off for 5 second as well. in the same circuit, i also required to interface led that will light on if I hit a switch.
here is my circuit :
as seen above i want to blink led on P0. then the led on P1 should on when i hit switch on P2.
I search through internet and get 2 codes. each is for each function (blink and switch). Can anyone help me how to make it into a single file?
here is the code for blink:
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
#include<reg52.h>
void delay(int time)        //This function produces a delay in msec.
    int i,j;
    for(i=0;i<time;i++)
     for(j=0;j<1275;j++);
void main()
     while(1)
          P0=0xff;
          delay(660);
          P0=0x00;
          delay(660);
and here is for switch:
Code C - [expand]
8
9
10
11
12
13
14
#include<reg52.h>
void main()
    unsigned char temp;
    P1=0Xff;
    P2=0Xff;
    while(1)
        temp=P2;
        P1=temp;
        while(P2==temp);
Thank you in advance :)
just try this code..
#include <reg51.h>
void delay()
unsigned int i,j;
for(i=0;i<5000;i++)
for(j=0;j<120;j++);
void main()
P2=0xff;
P0=0x00;
P1=0x00;
while(1)
if(P2^0==0)
P0=0xff;
delay();
P0=0;
P1=0xff;
delay();
P1=0x00;
hope this works
#include <reg51.h>
void delay()
unsigned int i,j;
for(i=0;i<5000;i++)
for(j=0;j<120;j++);
void main()
P2=0xff;
P0=0x00;
P1=0x00;
while(1)
if(P2^0==0)
P0=0xff;
delay();
P0=0;
P1=0xff;
delay();
P1=0x00;
hope this works
unfortunately not working :(. with this code, now the Leds on and off for 5 seconds instead 1 blink, and 1 by switch. I tried to combined 2 codes that i found, and the result is the switch also delayed.
thanks anyway for replying :D
Try this
#include<reg52.h>
unsigned char temp;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		delay(660);
		P0=0x00;
		delay(660);
		if(P2 == 1) {
			P1 = 1;
no luck also.. the same as I tried before. different way but same result. the switch is not working. it just on and off between them for 5 seconds each. this is frustrating :D
remove the 10k resistor going to led. It will work.
Your led connections are wrong. zip and post your proteus file and i will send the proper circuit.
Which led is not lighting, the D1? You have to use pullups on port 0
Try this code
#include<reg52.h>
unsigned char temp;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		delay(660);
		P0=0x00;
		delay(660);
		if(P2 == 1) {
			P1 = 0;
The problem is with the checking.
Try with this:
#include<reg52.h>
unsigned char temp;
unsigned char k;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		P3=0xff;
		for (k = 0; k < 22; k++){
			if (P2 == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
		P0=0x00;
		P3=0xff;
			if (P2 == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
I've added P3 along with P0. Remember that P0 needs pull-up. Connect LED like this:
I think this should work.
Hope this helps.
Tahmid.
i think i configure the led by turning the mcu into common ground. many sources tell me to put it that way even my lecturer.
i have the code for blink and switch. by that design, both of them works perfectly. but i have to make it as 1 code. thats my problem. the switch should light up D2. D1 is for blinking 5 sec and its works fine. but D2 not work properly when i tried to mix the code..
View attachment blinking led.rar
Did you try with my code in post #7?
Try this code. It will work.
#include<reg52.h>
unsigned char temp;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		delay(660);
		P0=0x00;
		delay(660);
		if(P2 == 1) {
			P1 = 0;
#include<reg52.h>
unsigned char temp;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		delay(660);
		P0=0x00;
		delay(660);
		if(P2 == 1) {
			P1 = 0;
Problem here is that the LEDs are blinked and then switch is checked. So, while the LEDs are being blinked, status of switch can not be checked. Thus switch response is slow.
Try with this:
#include<reg52.h>
unsigned char temp;
unsigned char i;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		P3=0xff;
		for (i = 0; i < 22; i++){
			if (P2 == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
		P0=0x00;
		P3=0xff;
			if (P2 == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
Hope this helps.
Tahmid.
okay so i configures all led that way, and now the Led that will be switched (P1) keep light up. the 5 seconds delay one works fine. yeah i think that way also. it just not check the switch somehow
So, you tried with this code?
#include<reg52.h>
unsigned char temp;
unsigned char k;
	int i,j;
	for(i=0;i<time;i++)
void main()
	while(1)
		P0=0xff;
		P3=0xff;
			if (P2 == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
		P0=0x00;
		P3=0xff;
			if (P2 == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
Can you clarify this? What do you mean by "not check the switch"?
yeah i tried. the result is led (switch) always on, and led(delay) normal. i mean, when i combine the codes,or use codes in this thread, the delay works normal but the switch just doesnt work.
Actually using an interrupt for the change of state of the switch and a timer interrupt for the flashing LED would be a more efficient method of coding your project.
The use of interrupts have distinct advantages over both polling for switch change of state and software delays.
Both polling and software delays force the code execution to pause or enter an inactive state, in effect burning cycles waiting for an event to occur.
While interrupts allow the system to service an event in a timely manner and return quickly to process other tasks.
BigDog
Realized the mistake in the code.
Try with this now:
#include<reg52.h>
unsigned char temp;
unsigned char k;
	int i,j;
	for(i=0;i<time;i++)
void main()
        P2=0xff;
	while(1)
		P0=0xff;
		P3=0xff;
			if ((P2 & 0x01) == 1){
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
		P0=0x00;
		P3=0x00;
				P1 = 1;
			else{
				P1 = 0;
			delay(30);
However, as bigdogguru mentions, use of interrupt and timer would be a more efficient method.
Hope this helps.
Tahmid.
Try with this now:
Hope this helps.
Tahmid.
it works like a charm. thanks man. yeah i think it should be done using interrupt for efficient result. gonna study about it.
