8051 and VT100 terminal - kit of CC1010 from chipcon
Humungus
Full Member level 6
Full Member level 6
I just bought the dev. kit of CC1010 from chipcon and there is an example program the requires that I emulate a VT100 terminal with data going in and out of my PC serial port. What they actually say is
IMPORTANT : Set up your terminal program to emulate a VT100 terminal for this to work properly. The baud rate is 57600 baud.
Do you know any program like that?
Thanks a lot
Humungus
Nick C.
Full Member level 5
Full Member level 5
Hyperterminal (which comes with Windows) should
work just fine. It will emulate VT100.
Nick C.
jarod
Newbie level 6
Newbie level 6
PC Port software
Hi, search the web for PComm Lite (think it comes from www.moxa.com). This is small but very nice and polite piece of software. I'm using it to communicate with GPS modems.
sgrudu
Member level 2
Member level 2
ITALY
You can use "crt" from Van Dyke:
www.vandyke.com
if you are under windows.
For linux you can use minicom.
