800-900MHz Local Oscillator
Thinh
Junior Member level 2
oscillator 900mhz
Hello,
Would you please tell me some Local Oscillator operating at :
870 ± 30 Mhz
error ±5Khz
Mixer at this range with minimum signal power at -132dB (or tell me about some LNA for this range compensation)
Thanks for advances
Thinh Phan
springf2000
Full Member level 6
i donot know what your -13dBm power means,in fact M/COM,minicircuit
all has the VCO works at the 800M-900M,so it is not a problem,so in the common way,you use the PLL to get the LO you wanted,may be -135dBc is the right,then it represent the phase noise
