andreikiss
Newbie level 2
Problem with 74LS47
Hello
I'm trying to do this project as a part of a bigger project :
https://engknowledge.com/microcontroller_interfacing_multyplexing_7_segment.aspx
But I have a few problems related on switching on and OFF the 7 segment display.
I use a Atmega168 microcontroler powered at 3.3V (because it is interfaced with a ENC28J60 ethernet controller).
I cannot switch OFF the PNP transistor(2N3906) running at 3.3 V .
And I tryed a NPN transistor(BC107) but i cannot switch them ON with 3.3V.
The 7 segment display the required digit(thanks to the 74ls47) but i cannot multiplex them.
I was thinking of optocouplers ???
Do you know ... is ULN2003A of any help in this situation ?
I need 9V on the 7 segment display to make it look bright.
Any help will be apreciated,
Thank you
Hello
![uC_Interfacing_7Segment_Schematic_small.png](https://engknowledge.com/documents/uC_Interfacing_7Segment_Schematic_small.png)
Thank you
