35Mhz Bandwidth Lock In Amplifier design help
Electronics_chaitanya
Member level 5
Member level 5
India
hello All
i want to design a lock in amplifier having frequency range of 40MHz.Actually i want to demodulate signal having frequency about 35 MHz.
I have searched on net but the amplifier i am getting are so much costly.Can you suggest any other way like Lab View for implementation of Lock in Amplifier.
In fact i m confused that is PC capable to accept such high speed (35MHz) signals? if yes then which port should i use for this app.
Any help is really appreciated actually we r gonna making life saving medical device.
-Regards
You need to clearly distinguish between signal bandwidth and carrier frequency. That may help clarify your specification.
Hello
Thanks for replay.Actually i am transmitting LASER modulated at frequency of 35MHz.I am using Crystal for giving 35MHz pulses to LASER diode and at receiving end i m using photo diode to obtain that 35MHz signal back.I want to just measure phase difference between transmitted and received signal.
but as per our professor at receiving end i must use lock in amplifier because received signal is consist lot of noise.
i have found a lock in amplifier on Google SRS810/SRS830. but its reference signal frequency is just only 120KHz.So can i use it? sorry for such question actually i am new to lock in amplifiers.
-regards
