30 MHz BW, GBW > 400 MHz. 1,2V Operatioanl Amplifer?
sudeep_
Member level 1
Member level 1
Can suggest me, which operational Amplifier is more suitable for high bandwidth (>30 MHz) with low power supply e.g (1.2 V)?
I am trying with a simple two-stage miller compensated Op-Amp, which is not providing the req.BW and GBW.
Input signal: 30 MHz, nm CMOS tech.
Thanks!
Some more info? What technology node, load capacitance, power consumption?
For the last 6 years the recycled architecture and it's variations are the hit for current efficiency, GBW and SR extension.
Hi again,
The technology node is 28nm bulk cmos, load capacitance around 1-1.5pF and power consumption doesnt matter atleast for now. But it would be better if it is low. For a 1V power supply the 3-dB BW must be around 40MHz.
Thanks
You didn't mentioned nothing about gain, but if GBW is ~400MHz and 3dB BW is 40MHz I assume that a gain constraint isn't high.
The single stage OTA loaded by 1.5pF needs an input transistors with transconductance at least 4mS to meet GBW requirement. You are able to achieve it with 700µA of tail current.
Try to start with the simplest 5 transistor OTA to check GBW and next develop it into folded cascode (for telescopic probably isn't so much headroom if your process doesn't provide low-Vth devices).
Expected gain is 30 dB in Closed loop. My bias current should not exceed more than 150 uA.
With this constraint (I_tot<150µA, GBW>400MHz) the only possibility is to base this ota on some variation of improved recycled cascode architecture or by applying to standard cascode a very good matched feedforward compensation scheme which completely cancel pole caused by output capacitance.
SR: 100 V/us
gm : 1.5 m
I will use Recycled cascode architecture.
