Use a voltage sensing relay and a contactor?....simple but effective.
How reliable do you need it to be? Ok perhaps three small 230V transformers wired in star, with a rectifier on the other side, and a comparator compared to a known reference, and then drive a contractor to drop out the motor, or disable an AC drive that would be running the motor? Most AC drives would allow you to drive in an analogue input 0-10V with a small PLC type program running on the drive. Input volts below a certain level; disable the drive output.
Normally, a correctly dimensioned motor circuit breaker or overcurren relay gives suffcient and reliable protection against all kinds of overloads and voltage failure. It's not obvious why it should not be sufficient for your application.
Industry standard overcurrent relays need a manual reset once they have tripped (the same with MCBs).Relays establishes the connection again when it bounce back, so I generally do not prefer i
