Help me analyze this Verilog code
shaiko
Advanced Member level 5
I need to analyze the following Vrilog code...
module SPORT_BUS(
            OSC_CLK,
            TSCLK0,         //4MHz DSP clk
            TFS0,           //DSP stobe
            DT0PRI,         //DSP Serial data input
            REC_DATA,       //8bit receive  data buffer
            RSCLK0,         //4MHz FPGA clk
            RFS0,           //FPGA storbe
            DR0PRI,         //FPGA Serail data output
            TR_DATA,        //8bit transmit data buffer
            RESET,          //global reset
            START,          //start tx
            NEW_REC,        //New data is ready
            READY
input           OSC_CLK;
input           TSCLK0;
input           TFS0;
input           DT0PRI;
input           RESET;
input           START;
input   [7:0]   TR_DATA;
output          RSCLK0;
output          RFS0;
output          DR0PRI;
output          NEW_REC;
output  [7:0]   REC_DATA;
output          READY;
wire            OSC_CLK;
wire            TSCLK0;
wire            TFS0;
wire            DT0PRI;
wire            RESET;
wire            RSCLK0;
wire            RFS0;
wire            START;
wire            NEW_REC;
wire    [7:0]   TR_DATA;
reg     [7:0]   REC_DATA;
reg     [13:0]  state1;
reg     [13:0]  state2;
reg             DR0PRI;
reg             READY;
reg             tsclk0_sampled2;
reg             tsclk0_sampled;
//assign  RSCLK0  =   TSCLK0;
assign  RSCLK0  =   tsclk0_sampled;
//                        s
//                        t
//                        r--1hot--43210;
parameter   idle    = 14'b00000000000000;
parameter   tx1     = 14'b11000000000010;
parameter   tx2     = 14'b00100000000011;
parameter   tx3     = 14'b00010000000100;
parameter   tx4     = 14'b00001000000101;
parameter   tx5     = 14'b00000100000110;
parameter   tx6     = 14'b00000010000111;
parameter   tx7     = 14'b00000001001000;
parameter   tx8     = 14'b00000000101001;
parameter   rx_dly  = 14'b00000000010011;
parameter   rx1     = 14'b01000000001010;
parameter   rx2     = 14'b00100000001011;
parameter   rx3     = 14'b00010000001100;
parameter   rx4     = 14'b00001000001101;
parameter   rx5     = 14'b00000100001110;
parameter   rx6     = 14'b00000010001111;
parameter   rx7     = 14'b00000001010000;
parameter   rx8     = 14'b10000000110001;
always  @(posedge   OSC_CLK or negedge  RESET)
    if(!RESET)
        begin
            tsclk0_sampled  <=  1'h0;
            tsclk0_sampled2 <=  1'h0;
        end
    else
        begin
            tsclk0_sampled2 <=  TSCLK0;
            tsclk0_sampled  <=  tsclk0_sampled2;
        end
//RX SPORT section
always @(negedge    /*TSCLK0*/tsclk0_sampled2 or negedge   RESET)
    if(!RESET)
        begin
            state2  <=  14'h0;
        end
    else
        begin
            case(state2)
                idle:
                        if(TFS0)
                            state2   <=  rx_dly;
                        else
                            begin
                                state2  <=  idle;
                            end
                rx_dly: state2   <=  rx1;
                rx1:    state2   <=  rx2;
                rx2:    state2   <=  rx3;
                rx3:    state2   <=  rx4;
                rx4:    state2   <=  rx5;
                rx5:    state2   <=  rx6;
                rx6:    state2   <=  rx7;
                rx7:    state2   <=  rx8;
                rx8: begin
                          if(TFS0)
                            state2   <=  rx_dly;
                          else
                            state2   <=  idle;
                        end
                default:  state2   <=  idle;
            endcase
        end
//TX SPORT section
always @(posedge    RSCLK0 or negedge   RESET)
    if(!RESET)
        begin
            state1  <=  14'h0;
            DR0PRI  <=  1'h0;
            READY   <=  1'h1;
        end
    else
        begin
            case(state1)
                idle:   begin
                            READY   <=  1'h1;
                            if(START)
                                begin
                                    state1   <=  tx1;
                                end
                            else
                                begin
                                    state1  <=  idle;
                                    DR0PRI  <=  1'h0;
                                end
                        end
                tx1:    begin
                			READY   <=  1'h0;
                            state1  <=  tx2;
                			DR0PRI  <=  TR_DATA[7];
                		end
                tx2:    begin
                			state1   <=  tx3;
                			DR0PRI  <=  TR_DATA[6];
                		end
                tx3:    begin
                			state1   <=  tx4;
                			DR0PRI  <=  TR_DATA[5];
                		end
                tx4:    begin
                			state1   <=  tx5;
                			DR0PRI  <=  TR_DATA[4];
                		end
                tx5:    begin
                			state1   <=  tx6;
                			DR0PRI  <=  TR_DATA[3];
                		end
                tx6:    begin
                			state1   <=  tx7;
                			DR0PRI  <=  TR_DATA[2];
                		end
                tx7:    begin
                			state1   <=  tx8;
                			DR0PRI  <=  TR_DATA[1];
                		end
                tx8:    begin
                		    DR0PRI  <=  TR_DATA[0];
                		  /*if(START)
                            begin
                              state1   <=  tx1;
                            end
                          else
                            begin
                                state1  <=  idle;
                            end*/
                		    state1  <=  idle;
                        end
                default:  state1   <=  idle;
            endcase
        end
assign  RFS0    =   state1[13];
assign  NEW_REC =   state2[13];
// RX
    always  @(posedge   state2[12])
        begin
            REC_DATA[7]  <=  DT0PRI;
        end
    always  @(posedge   state2[11])
        begin
            REC_DATA[6]  <=  DT0PRI;
        end
    always  @(posedge   state2[10])
        begin
            REC_DATA[5]  <=  DT0PRI;
        end
    always  @(posedge   state2[9])
        begin
            REC_DATA[4]  <=  DT0PRI;
        end
    always  @(posedge   state2[8])
        begin
            REC_DATA[3]  <=  DT0PRI;
        end
    always  @(posedge   state2[7])
        begin
            REC_DATA[2]  <=  DT0PRI;
        end
    always  @(posedge   state2[6])
        begin
            REC_DATA[1]  <=  DT0PRI;
        end
    always  @(posedge   state2[5])
        begin
            REC_DATA[0]  <=  DT0PRI;
        end
endmodule
A few questions:
1. What is the purpose of rx1,rx2,rx3,rx4,rx5,rx6,rx7,rx8,rx_dly,idle ? Why are they parameterized ?
2. As I see : "tsclk0_sampled2" is sampled using the "OSC_CLK" signal. However, it's also used in the second "always" under the "negedge" statement. this will yield a gated clock - correct ?
Looks like a FSM.
1. All the rx1...rx8 etc you mention are the states of the FSM. They are parameterized because that's a convenient way to define your FSM states.
//                        s
//                        t
//                        r--1hot--43210;
And as you can see it's a combination of 5-bit binary number in the LSB, then some 1-hot state encoding, and the MSB looks like a set/reset or somesuch.
That's where the "set/reset or somesuch" gets assigned to signals to be used elsewhere. Could be a strobe, what with the "str" now that I think about it.
Reactions: shaiko
    shaiko
I've never seen such FSM written in VHDL...
VHDL uses simple enumaration for the states. why Verilog is different?
dave_59,
I'm used to describing state machines in VHDL.
I often use the registered Meally type with a single synchronous process.
Can I do the same thing with Verilog? I mean describing a registered Mealy FSM with a single "always" block?
ok,
another question.
please look at the following section of code:
        begin
        end
        begin
        end
        begin
        end
        begin
        end
        begin
        end
        begin
        end
        begin
        end
        begin
        end
It will create a lot of gated clocks - right ?
I don't think you get gated clocks, I am not 100% certain. The code is a bit dodgy IMHO. What I am pretty sure about is that whoever wrote this verilog code did not intend it as gated clocks.
If you look at this bit:
Code Verilog - [expand]
8
9
10
11
12
13
14
15
//                        r--1hot--43210;
// ... snip ...
Then you see that state2[12] ... state2[5] correspond with those rx1 .. rx8 states. Them thar be one-hot encoded states.
Now while those @posedge's probably work, I don't think it's the best idea ever. IMO a better practice is to write it like so:
8
9
10
11
12
always @(posedge clock) begin
    case(1'b1) begin // synthesis parallel_case
      state2[12]: REC_DATA[7]  <=  DT0PRI;
      state2[11]: REC_DATA[6]  <=  DT0PRI;
      state2[10]: REC_DATA[5]  <=  DT0PRI;
      state2[9] : REC_DATA[4]  <=  DT0PRI;
      state2[8] : REC_DATA[3]  <=  DT0PRI;
      state2[7] : REC_DATA[2]  <=  DT0PRI;
      state2[6] : REC_DATA[1]  <=  DT0PRI;
      state2[5] : REC_DATA[0]  <=  DT0PRI;
    endcase
end
That does the same thing as what I think is intended here, but keeps things a bit more readable. And for bonus points you can parameterize things so you get this:
8
9
10
11
12
13
14
15
16
parameter RX1=12;
parameter RX8=5;
      state2[RX1]: REC_DATA[7]  <=  DT0PRI;
      state2[RX2]: REC_DATA[6]  <=  DT0PRI;
      state2[RX3]: REC_DATA[5]  <=  DT0PRI;
      state2[RX4]: REC_DATA[4]  <=  DT0PRI;
      state2[RX5]: REC_DATA[3]  <=  DT0PRI;
      state2[RX6]: REC_DATA[2]  <=  DT0PRI;
      state2[RX7]: REC_DATA[1]  <=  DT0PRI;
      state2[RX8]: REC_DATA[0]  <=  DT0PRI;
    endcase
end
Note that the RX1 .. RX8 are suspiciously much like the lower case rx1 ... rx8. So I would NOT actually use this particular bit of code verbatim in your original code. This is more so you get the idea.
Edit: Oh yeah, and don't forget those "synthesis parallel_case", otherwise you just might get Priority Encoders of Slowness & Suffering. To see what that does see the XST user guide.
Reactions: shaiko
    shaiko
It looks like the coder wanted to implement 2 simple shift registers with 2 complex and unorthodox FSMs
What else can you get out of 8 unrelated always blocks with a signal other then a clock triggering the FF ?
Answer: Whatever the hell the synthesis tool comes up with this time. :p
But if you really want to know, just plug it in and synthesize it.
