why master flip lfop is level triggered?
Sh!BB!
Newbie level 1
can any1 temme dat why master flip flop is level triggered in MASTER SLAVE FLIP FLOP?
Because that's the way it's built...
Look at the DFF drawing below and analyze each logical path to the gates with a truth table.
The FlipFlop is usually described as "positive-edge-triggered". You find the same gate level diagram for TTL IC 7474 (with additional nPRE and nCLR inputs).
Please notice, that all usual edge-triggered circuits, e.g. CMOS transfer gate designs are level sensitive at the transistor level and don't involve any dynamical circuits e.g. with capacitors. Edge sensitive means, that the input state is sampled and transferred to the output during the clock edge, at no time there's a direct input to output connection as in a transparent latch.
Correct edge sensitive behaviour can be only guaranteed if the specified maximum CLK risetime is kept.
FvM,
Are you saying that there's a limitting rise time for the CLOCK signal beyond which the FF won't work correctly ?
There's a maximum rise time specification in most logic datasheets. For slow clock edges, correct operation isn't guaranteed. With some digital devices, clock inputs may have an internal schmitt-trigger circuit to overcome the problem.
