please can anyone help me with Additional Proteus Library
compaq47
Newbie level 3
Namibia
Hi please i would like to have more library for Proteus ver 7.1
thanks peeps!!!:roll:;-):!::!::!:
There are not any additional libraries for proteus , there are only the ones sold by labcenter, I hope you are not asking for them :evil:.
From time to time a see a post about custom components in proteus but not libraries with many components.
Alex
alright thanks, how about the custom components like a transformer? i need only a transformer to simulate a power supply.
there are several transformers in proteus but they are not named transformers.
Open the component dialog and write TRAN-, you will see four models, also add VSINE in the project as the AC voltage source for the transformer
Alex
thanks it was useful but how can i change it for it to regulate from 200v, 60hz into 12v?
---------- Post added at 18:22 ---------- Previous post was at 18:21 ----------
thanks it was useful but how can i change it for it to regulate the input of 200v, 60hz into the output of 12v?
double click the transformer and change the transformer ratio, or since the default is 1/1 use a 12V AC source in the primary and also set the source frequency to 60Hz
Alex
Alex
hi,
may i know wat do u mean by adding VSINE in the project? it is adding in a alternator?
