Hello,
We want to put a 20W LED tube into a socket for a fluorescent tube with a high frequency, switch mode fluorescent ballast driver.
...we dont want to remove the fluorescent ballast as it would be inconvenient.
Are there any standard solutions for this?
-we still want it to be quite efficient, so dont want a linear driver to be added in for the LED current control...we want efficient switch mode current control of the LED current.
...Ultimately, we would like to design a 20W LED tube (containing auxiliary circuitry and converter , etc) which could run off ANY fluorescent ballast.
..that is, it should be able to run off either a 50Hz magnetic ballast, or any high frequency switch mode fluorescent ballast.
....do you know if standard solutions exist for this?
