2,5V @ 20ppm voltage reference
fjpompeo
Advanced Member level 1
Brazil
lm341a
Is it possible to get a 2,5V with 20ppm voltage reference using LM341A IC?
If not what should I use instead?
Regards,
Fernando
A 20 ppm reference is going to be a little more expensive than the regular 50 ppm ones.
I recommend
TI's REF3125: http://focus.ti.com/docs/prod/folders/print/ref3125.html
Maxim: MAX6033, MAX6035, or others: **broken link removed**
Analog Devices: AD680, ADR03 or others: www.analog.com/dynamic/parametric/scResultsDisplay.asp?SearchType=PSS&ProductLine=REF
Linear Technology: LT1460 www.analog.com/dynamic/parametric/scResultsDisplay.asp?SearchType=PSS&ProductLine=REF
Intersil ISL60002DIH325, or others www.intersil.com/products/deviceresults.asp?i=14925
