deperkin
I am thinking about using an 18F46k20 microchip.
This is a low voltage pic, and it does mention that the voltage on any pin is to be
-0.3V to (VDD + 0.3V). I would plan on using a 3.3V power supply for this application.
I also have a MPXV7002GP pressure sensor I would like to use.
The output voltage on this is from 0.5 to 4.5V, which seems to be to be a problem with this PIC.
I admit I have not completely read through the datasheet for the PIC yet however.
I also have not been able to find an alternate pressure sensor.
I would imagine this is a common question for this PIC, although nothing I saw in searches suggested this.... What is the best way to use sensors, ADC or TTL that have 5V outputs? I need to be accurate on the pressure sensor and do not see using a resistor in this case the correct way to approch it...
