abuhafss
Full Member level 2
Hi
I am building 12v 30A DC power supply shown at
I am using two separate water cooled heat sinks ----- one for the 6 transistors and the other for the bridge rectifier & voltage regulator LM7812. Both the heat sinks are connected in series i.e. the cooling water from the 1st heat sink goes into the 2nd heat sink and then to the radiator.
The circuit did not worked and found LM7812 to be the culprit. I wonder if the water circulating in the heat sinks is making any sort of conduction between GROUND (from LM7812) and COLLECTORS of the transistors, which might have ruined LM7812 OR simply LM7812 was actually faulty. I will get the new LM7812 soon but before installing it I would like to have some valuable comments.
