110/220 AC to 5/12 DC without Transformer
azerm
Member level 1
Member level 1
power supply without transformer
Hello,
I need a circuit for 5v/12v DC supply from 110/220 AC. The common way is to use a transformer, a bridge and a voltage regulator. I know this way, but it is needed to be done without using trans becasue of its weight. The maximum current is 500 mA. A friend told me to use HV capacitors instead of Trans to reduce the AC voltage, the other parts are the same.
Is it possible to make this circuit? Is any idea about it? Does anybody know any reference?
Thanks in advance.
IanP
Advanced Member level 7
West Coast
ac to dc without transformer
Transformless Power Supply:
Regards,
IanP
    azerm
Davood Amerion
Advanced Member level 2
Persia
220 ac to 12 dc
transformerless power supply for 500mA current
is not economic. it is better to use switching power supply with one IC and small ferrite transormer
flatulent
Advanced Member level 6
Middle Earth
12dc 220ac
There is also the safety issue. Transformers should always be used in home built projects.
marie65
Super Member
Full Member level 4
ferrite transformer ac to dc
Check Rohm's AC/DC modules:
    azerm
Sebi
Member level 3
Member level 3
Hungary
220 ac to 5 dc
The X2 type capacitor for 500mA is quite bigger than a small transformer!
Check the Power Integration TOPswitch-serie.
nikhilele
Advanced Member level 3
Bangalore India
Davood Amerion Posted:
I would like to more about this configuration
manu
Full Member level 3
Full Member level 3
France
12 dc transformer
See this topic :
badboy2007
Full Member level 1
Cambodia
power supply design without transformer
it low amp. i want 5A how i do?
Electronics Boy
circuit+220v+without transformer
use TOP Switches such as TOP226 . see datasheet .
eem2am
Banned
500ma transformerless power supply
yes ok, but remenber ing as already said for safety of isolation via trxformer is good.
but you can just rectify and use a buck converter if you wanmt...but it will have low duty cycle but who cares ?
so just use a buck.....and a high side driver u use bootstrap driver as you dislike pulse transformer i think.
and can the LNK306 DO 500 mA...? if it can ur prob is solved
it is from powerint.com
what about a tapped buck converter....which has longer duty cycle for you.
