10Ah ups battery charger schematic needed. . . . .help
jami007
Full Member level 3
Pakistan
can anyone plz send me schematics for 5 to 10Ah ups battery schematics. i've to submit my final year project at the end of june 2010. . . . . .
use 230vac 0-15vac 5amp transfr. add br 10w10 bridge (u can use 1n5408 diode1*4)
use 2200mfd/ 35vdc cap , use lm317t as an voltage regulator set the o/p to 13.8vdc
now u can charge 5 to 10amp battery.
....:D:D:D
10AH is not a big battery, so the charger doesn't need to be to complicated ..
Here are descriptions of suitable chargers based on the popular voltage regulators, namely the LM317, the LM350 and L200:
It looks like the version based on the LM317 would be just the right size .. see picture below ..
IanP
:D
thanks bro, but ups uses 100-110AH battery, and its not small. . . . . . . :)
Its your project and you expect some one else to do your home work?...Intresting..
Than is your title of topic (& your begining texts too)WRONG!! :-(
K.
my project is a sine wave ups and i completed the inverter design and now converting it into a ups. i dont have time to design a power supply of 10-20A thats why I call for help. i made a mistake in writing spec. i need 10-20A charger or power supply schematics
    jami007
Hi Moderator,
OK_sorry!
regards
K.
here are some solar battery charger schematics
  • Solar.zip
here is a battery charger circuit
  • Battery Charger.PDF
