100 points for matlab code
jinal patel
Full Member level 1
Hi to all..
I am doing my project on Speech Recognition system..for this i required a matlab code for Speech Recognition (not identification)..Means i want to varify a stored character (or word if possible) speek by ANY speaker.. When ever a particular word or character is varified, then i should get high output on parallel port..If accurate code is available in C/C++ then also its allowable for me..
In short whenever any speaker will speek a pre-stored character then output of parallel port pin will be high..
please help me ..its urgent
alzomor
Advanced Member level 2
Germany
Hi
You can search for hiddn Markove chain
It's used to implement speach recognetion
also you can check this
Salam
Hossam Alzomor
visioneer
Full Member level 1
jinal patel said:
Hi to all..
Sphinx is CMU's award winning speaker-independent large vocabulary continuous speech recognizer.
You can find the all the source codes and documents from the followng link.
https://sourceforge.net/projects/cmusphinx/
proper
INDIA
For speach recognition .. i coded some algorithm but its need to check for large data base. That is currently under processing.
plz write your query ..if possible i try to solve it.
Thanks
triump.ar
Junior Member level 2
i m attaching the file...i dont know it will work for u or not...but u cn get some help....
supiper
Member level 3
TUNISIA
Hidden Markov Model (HMM) is the only possible way for speech recognition. Implementing HMM on Matlab is a difficult task. However, you can use HTK for HMM modeling and you can use this model with Matlab code:
https://htk.eng.cam.ac.uk/
jigisha
Full Member level 2
hi.......
well u can take help from colea.in which some of the simplest prog are already given.and if u need i can give u the soft material for c/c++.....
well try also in google .....may be u get it in future....!!!
best luck...
jinal patel
Full Member level 1
Jigisha, colea is the software through which we can record our speech with desirable time bounded and its useful for analysis of speech parameters. We can use colea as a tool but i am in need of matlab code of speech recognition.
supiper
Member level 3
TUNISIA
jinal patel
Full Member level 1
Supiper, i donot know how to implement HMM on matlab.
supiper
Member level 3
TUNISIA
Download the HMM toolbox and read the attached file.
calm
Full Member level 4
search them on the internet
saleheen
Member level 3
This code might not be directly associated with speech. But its rather on array beamforming.. Similar concept. Hope this helps you get started..
scintillatingstuffs
Junior Member level 3
it will always be better if you type the codes urself... u can make it flexible based on ur needs... unlike in a borrowed code where u need to spend hack lot of time learning what it is all about.............
