I was designing a system, and the customer wanted to operate it on 10MHz.
There was a 10 Millisecond counter in that design, so I applied a 17 bit counter that gives a tick every 10 milliseconds based on this frequency. The code was like that:
always @(negedge sys_rst_n or posedge sys_clk) begin
if (~sys_rst_n) begin
counter_tms <= 17'b00000000000000000;
counter_done <= 1'b0;
end else begin
if(opmode != go_to_mode) begin
counter_tms <= counter_tms + 1'b1;
if (counter_tms > 17'b11000011010100000) begin
counter_done <= 1'b1;
end else counter_done <= 1'b0;
end else begin
end
end
end
Is there any method that no matter what sys_clk is, we are always count 10ms? I thought about parameterization, but how cant imagion that. Can some body help in this regards? For now, lets assume that frequency is 1 to 10MHz.
It depends if your goal is to have it change in real time, or parameterised before the build?
Either way, you need some mechanism to work out what the counter needs to count to based on the sys_clk frequency, which needs to be a parameter or control signal somehow.
Do you understand the difference between port signals and parameters?
Unless the clock frequency is switched in operation, you want most likely to implement a clock frequency parameter. The counter bit width and compare value can be calculated at compile time in Verilog.
