Modelsim error ** Error: (vsim-3601) Iteration limit reached at time x us.
gongdori
Full Member level 2
Hi all,
I am getting a modelSim error from post translate simulation. The error says that it reached the max iteration during the simulation.
This error does not come out in the behavioral simulation, and persist even if I increase the max iteration value.
It seemed that there was a loop in the VITALBehavior process of X_LUT3, but I don't understand why.
Below is the process
  VITALBehavior           : process (ADR0_ipd, ADR1_ipd, ADR2_ipd)
    variable O_zd         : std_ulogic;
    variable O_GlitchData : VitalGlitchDataType;
    variable I_reg    : std_logic_vector(2 downto 0);
  begin
    I_reg := To_StdLogicVector(ADR2_ipd & ADR1_ipd & ADR0_ipd);
    if ((ADR2_ipd xor ADR1_ipd xor ADR0_ipd) = '1' or
        (ADR2_ipd xor ADR1_ipd xor ADR0_ipd) = '0') then
       O_zd := INIT_reg(SLV_TO_INT(I_reg));
    else
       O_zd :=  lut4_mux4 (('0' & '0' & lut4_mux4 ( INIT_reg(7 downto 4), I_reg(1 downto 0)) &
                lut4_mux4 ( INIT_reg(3 downto 0), I_reg(1 downto 0))), ('0' & I_reg(2)));
    end if;
    VitalPathDelay01 (
      OutSignal            => O,
      GlitchData           => O_GlitchData,
      OutSignalName        => "O",
      OutTemp              => O_zd,
      Paths                => ( 0 => (ADR0_ipd'last_event, tpd_ADR0_O, true),
                                1         => (ADR1_ipd'last_event, tpd_ADR1_O, true),
                                2         => (ADR2_ipd'last_event, tpd_ADR2_O, true)),
      Mode                 => VitalTransport,
      Xon                  => Xon,
      MsgOn                => MsgOn,
      MsgSeverity          => warning);
  end process;
It looks that what's modified in this process is O_zd. However, the process is called again and again. I don't see where the signals on the sensitivity list are modified...
Does anyone have any clue?
Thanks,
Gongdori
My code is as simple as this:
generate
genvar i;
for ( i = 0; i < WIDTH; i++) begin
MUX4 #(.INIT(16'hABCD)) mux (
.I0(Z_TMP),
.I1(A),
.I2(IN),
.I3(1'b0),
.O(Z_TMP)
end
endgenerate
I have a similar issue:
# ** Error: (vsim-3601) Iteration limit reached at time 21845 ns.
# Can't find the loop!!!
For me, there's a "can't find the loop" too. I wonder what it means.
INIT_reg is missing from the sensitivity list, which is probably whats causing it to pass behavioural simulation.
Also check you havent got a combinatorial loop with any of the other signals.
Thanks for your comment. INIT_reg is a function, not a signal. All inputs of that function are on the sensitivity list. If a signal which should be in the sensitivity list is not there, it should not cause infinite loop, I think...
The synthesisor ignores the sensitivity list and just generates the logic as per the code in the process. Hence you can easily have a simulation/synthesis missmatch if you miss some signals from the sensitivity list.
