How to convert Hex values to Binary or Decimal using C/C++
Re: How to convert Hex values to Binary or Decimal using C/C
Try:
/* Let hex value in micro be num, divide by 10 and keep remainder, call it value */
value = num % 10;
num /= 10;
/* Carry on till value become Zero! */
ok Here you go: You can build and debug in Keil!
/* Prototype */
void Hex2Decimal(unsigned long num);
/* Hex Variable in any register */
unsigned long num = 0x499602D2 ; /* 1234567890 */
int main (void)
Hex2Decimal(num); /* Convert given hex to decimal digits */
return 1; /* Good C!, not required */
/* Function */
/* Converts an unsigned hex number availabe in the micro registers to decimal digits
and stores the decimal digits in an array */
unsigned char value[10];
unsigned char i = 0;
while(num > 0)
value = num % 10;
num /= 10;
i = i + 1;
