abhaykotnala
Junior Member level 1
i want to short the patch and the ground plane if i do so by uniting all the ground plane shoring cylinder and patch it gives error patch and substrate intersect.......bt if i only make the cylinder just touching the patch and ground plane it dsnt give error
is this right method of shorting or is it necessary to unite them.....plzzzz suggest some possible solution to it in regard to hfss
