teongkia
Newbie level 2
Hi I have this code. I tried it out in microcontroller but didn't work. I am currently having a car security project. What I want is when any of the sensor is triggered (high voltage in input pin), it will have high voltage in output siren pin and call the predefined owner's number. Can anyone check for it and let me know what is the problem?Thanks.
//Preprocessor
#INCLUDE <16F877.H>
#FUSES HS,NOWDT,NOLVP
#USE DELAY(clock=12000000)
#USE RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
//Define pin
#DEFINE SIREN PIN_B5
#DEFINE CL1 PIN_B4
#DEFINE CL2 PIN_B3
#DEFINE ULTRA PIN_A0
#DEFINE TOUCH PIN_A1
#DEFINE LIGHT PIN_A2
#DEFINE DOOR PIN_A3
#DEFINE REMOTE PIN_A4
//Global declaration
int A,B,C,D,RC,EN;
int RC1[2];
char SENSOR1, SENSOR2, SENSOR3, SENSOR4, SENSOR5, TEMP;
char P[4];
char S[51];
//Sound siren
void SIREN_ON()
OUTPUT_HIGH(SIREN);
DISABLE_INTERRUPTS(INT_RTCC);
//Unlock doors
void UNLOCK()
OUTPUT_HIGH(CL1);
OUTPUT_LOW(CL2);
//Lock doors
void LOCK()
OUTPUT_LOW(CL1);
OUTPUT_HIGH(CL2);
//Ultrasonic sensor triggered
void SEND_CALL1()
PRINTF("ATD0123456789;\n\r");
//Touch sensor triggered
void SEND_CALL2()
//Light sensor triggered
void SEND_CALL3()
//Door sensor triggered
void SEND_cALL4()
//Central lock triggered
void SEND_CALL5()
#INT_RTCC
T0()
SENSOR1=INPUT(ULTRA);
SENSOR2=INPUT(TOUCH);
SENSOR3=INPUT(LIGHT);
SENSOR4=INPUT(DOOR);
SENSOR5=INPUT(CL1);
if(SENSOR1)
SEND_CALL1();
SIREN_ON();
else if(SENSOR2)
SEND_CALL2();
SIREN_ON();
else if(SENSOR3)
SEND_CALL3();
SIREN_ON();
else if(SENSOR4)
SEND_CALL4();
SIREN_ON();
else if(SENSOR5)
SEND_CALL5();
SIREN_ON();
#INT_RDA
SERIAL()
//Optional
if(kbhit())
TEMP=GETC();
if(A<50)
S[A]=TEMP;
A++;
else
A=0;
S[A]=TEMP;
A++;
DELAY_MS(100);
return A,S;
//Main function
void MAIN()
SET_RTCC(0);
SETUP_COUNTERS(RTCC_INTERNAL,RTCC_DIV_64);
EXT_INT_EDGE(0,H_TO_L);
ENABLE_INTERRUPTS(INT_EXT);
ENABLE_INTERRUPTS(INT_RDA);
ENABLE_INTERRUPTS(GLOBAL);
ENABLE_INTERRUPTS(INT_RTCC);
SET_TRIS_A(0x3F);
SET_TRIS_B(0x01);
//SET_TRIS_C(0x0F);
SET_TRIS_D(0x00);
DELAY_MS(5000);
PRINTF("\n\rATZ\n\r");
DELAY_MS(500);
PRINTF("\n\rAT\n\r");
DELAY_MS(500);
PRINTF("\n\rAT+CNMI=2,3,0,0,0\n\r");
DELAY_MS(500);
SENSOR1==0;
SENSOR2==0;
SENSOR3==0;
SENSOR4==0;
SENSOR5==0;
A=0;
B=0;
C=0;
D=0;
EN=0;
RC=0;
UNLOCK();
