turuk
Junior Member level 3
In my antenna design, for more than 3,6 billion cells required and when i try to run the program i got this error message
"Simulation setup for 3.6 billion mesh cells requires:
- MPI simulation setup with at least 2 cluster nodes
Simulation cannot be started."
Is there any of you faced with the same problem? Even for the reduced number of cells it cannot run the program plus i dont wana use less number of cells since it affects the results.
Any advice would be really helpful
Thanks in advance
Thanks in advance
