Results 1 to 6 of 6
    Newbie level 3
    Points: 32, Level: 1
    Mar 2020
    32
    Bootstrapping with Opto Driver
    Hi team!
    There is a bootstrap gate drive circuit for a inverter that I take the project of a graduate student as a reference and it works. But there are a few things that I don't understand in this circuit.
    Like ;
    -Why does the PWM signal come from the cathode to the anode?
    -Why is a capacitor placed between the cathode and the anode?
    -Why 12V is given externally to the anode? or
    ( Doesn't the opto coupler work without biasing the Anode? )
Name:	Bootstrapping Circuit Ex..JPG
    Points: 83,859, Level: 70
    Apr 2014
    17,050
    83,859
    70
    Re: Bootstrapping with Opto Driver
    this is an inclomplete circuit. I donīt think it is correct. It does not make sens to discuss abut an incomplete circuit.
    Where is it from? --> give a link ..
    and give full description.
    Newbie level 3
    Mar 2020
    32
    Hi sır ,
    The Opto Driver IC is the HCPL-3120 above ,
    Also i will send another picture below wich includes 2 pre-bias supplies like the picture above.
    He got the same things , only the difference is that they give 5V instead of 12V.
    the driver section is taken by EG8010+TLP250.
    The link the link :)
    https://www.lz2gl.com/data/power-inv...tasheet_en.pdf
    Apr 2014
    17,050
    83,859
    70
    This circuit makes more sense:
    It differs to the first one:
    * Now there is no capacitor beween A nd C of the LED. It is between pin2 and GND. Mind the junction dot.
    * It seems to be a low side driver and a high side driver
    * low side driver pin5 is connected to GND
    * high side driver pin5 is connected to the half bridge
    * LED power supply now is 5V.
    * maybe others...
    Now to your questions.
    what does this mean?
    No. The capacitor is NOT connected between C and A.
    What is the alternatice you see? Why do you ask?
    or( Doesn't the opto coupler work without biasing the Anode? )
    the input of the optocoupler is a LED. It needs current to flow, it needs some power.
    It is very basic knowledge that any LED will need both pins connected to be able to work.
    ... or did I misunderstand the question?
    Newbie level 3
    Mar 2020
    32
    First of all, thank you very much for answering very quickly sir!
    I want to explain the reason by giving an example ,
    when the PWM signals are applied, a voltage of 12V comes already to the anode of the IC.
    In addition, I could not understand why it was directly powered by 12V with a pre-biased supply.
    I mean , can't i just feed the opto - driver with the amplitude of the pwm signal?
    Thanks in advance.
    Apr 2014
    17,050
    83,859
    70
    This all makes no sense to me.
    --> Show a sketch/circuit about your idea.
