+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Pavlanto
    Error in Cadence Virtuoso DRC
    I am running a simple DRC check in Cadence virtuoso.My error is PP.EN1:{NP OR PP} enclosure of PO (except of PO) >=0.15um.
    I am running a simple NAND circuit with one Pmos and one Nmos transistor.I use a via to connect the input(metal 1) with the gates(poly).
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 39,734, Level: 48
    Join Date
    Mar 2008
    USA
    Posts
    6,419
    Points
    39,734
    Level
    48
    Re: Error in Cadence Virtuoso DRC
    Yes? So?
    Have you read the design rules document? It should be
    clear about the meaning and logic of the rule. And the
    marker should show you the location of what's missing.
    I'll leave aside the improbability of making a NAND gate
    with only one of each transistor, or the difference
    between contact and via.
    •   AltAdvertisement
  3. #3
    Pavlanto
    You are right.I designed a NOT gate,thats why i used only 2 transistors.I had a try with a NAND and had the same problem.Of course i know the exact place of the error.It is between the via and the poly.
    Here are 3 photos with the circuit,the vias settings and the error
    Click image for larger version.
    •   AltAdvertisement
  4. #4
    Join Date
    Mar 2008
    USA
    Posts
    6,419
    Points
    39,734
    Level
    48
    If I had to guess further I'd think this is a poly-must-be-doped
    rule, and that perhaps (as at many foundries) the field poly is
    doped by some Boolean rather than hand drawing P+ or N+ on
    all of your local interconnect.
    Often this is dependent on some feature like "bulk" which has
    to surround the circuit but is not a masking layer. Take a
    look at any library cells that may exist for features you
    don't recognize / understand.
    I still recommend that you read the design rules pertaining
    to the error. Add to this the section on mask booleans and
    parsing the DRC rule for its logical terms, which should be
    directly illuminating.
