Results 1 to 5 of 5
    Junior Member level 1
    Points: 200, Level: 2
    Feb 2015
    17
    200
    Programming a square signal
    My problem is I can't have a square signal, which its period is 500 s and its duty cycle is 10%, with a function generator. So, I think I can you a FPGA to program a such signal.
    What do you think, it's feasible or not?
    Emie
    Points: 8,521, Level: 22
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germany
    1,276
    8,521
    22
    Blog Entries
    Re: Programming a square signal
    You just want to generate a signal with period = 500us and 10% duty cycle right?
    Why to make things complicated and use an FPGA? Yes definitely it is possible.
    But you can just program a generic uC and get that type o/p too.....way more easier (assuming you are not familiar with FPGAs).
    FPGA enthusiast!
    Feb 2015
    17
    200
    Yeah ! I want to program a signal with period = 500 s and duty cycle = 10%.
    But the problem is my function generator has 20% such as duty cycle min value.
    if there is an easier way to solve my problem, I can use it, instead of using FPGA :)
    Dpaul, what do you mean by a generic uC?
    Points: 10,056, Level: 24
    ALERTLINKS's Avatar
    Dec 2003
    Pakistan
    1,259
    10,056
    24
    Use a 4017 decade counter IC. Feed it with 20KHz. Take output from any pin.
    I know. I know. And once more - I don't know.
    I am too old and would not have enough knowledge to judge, and only have made some remarks in order not to be called ignorant.
    dpaul's Avatar
    Jan 2008
    Germany
    1,276
    8,521
    22
    Blog Entries
    Quote Originally Posted by emie View Post
    A programmable micro-controller I meant.
    FPGA enthusiast!
