CatKing
Full Member level 3
Not source file, IPO is to optimize your placed design, so you must export the netlist after placement and CTGen, but because of the interconnection and loading may be different as DC estimated, so you have to adjust(insert/delete/resize) the drive strenth of your driver source of the nets, that's exactly the resynthesis does, that's why resynthesis needs custom ILM(or SDF) files from placement.linuxluo said:... When I resynthesis, I use the source file and wlm above to generate optimized netlist , and again sta and p&r until timing closure.
Is it true?
Thanks.
So after resynthesis, the netlist changed from the last placed netlist, you have to do ECO placement again, repeat this IPO iteration until all timing are closure.
