Faizan Jawaid
Full Member level 3
- Joined
- Jul 17, 2008
- Messages
- 189
- Helped
- 23
- Reputation
- 46
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Karachi, Pakistan
- Activity points
- 2,336
This is not big issue buddy. Please post a complete schematic.
#include<16f877A.h>
//#use delay (clock=20000000)
#use delay (clock=03579545)
#fuses NODEBUG,HS,NOWDT,PUT,NOPROTECT
#use rs232(baud=2400,xmit=PIN_C6,rcv=PIN_C7)
main()
int i;
set_tris_a(0x00); //se
set_tris_b(0x00); //se
set_tris_d(0x00); //se
set_tris_e(0x00); //se
while(1) {
i=65;
do
putc(i);
delay_ms(1000);
i++;
while(i<=122);
b4bb4ge said:I am having the same problems with the UART and my body coming close / touching the microprocessor and then the system freeks out.
I am using both the pic16F88 and a Pic18F and they are both having this issue.
When / if I solve this problem I will let you know what solved it for me.
#use delay (clock=20050000)
