How to generate a reference current of 5uA?
surianova
Advanced Member level 1
ASIA
hi all!
i need to generate a reference current of 5uA. This 5 uA must indepedent of power supply, process and temperature. Any idea or journal i can refer to generate this current? Thanks in advance.
Reference current
There are four type of current sources. They are proportional to absolute temperature (PTAT); gm-matching; temperature independent;and currents with a negative temperature coefficient (TC). Find in google any of this current source. Or
https://www.freepatentsonline.com/ :)
Re: Reference current
but all these is temperature dependence.
surianova said:
hi all!
Chk if this post if it can help you
It's very difficult in analog design to obtain PVT stable current reference with high tolerance.
U can make bandgap reference to get stable voltage with 2-3% tolerance (without trimming). To make stable current u can use off-chip resistor. It's one way.
The second one is using on-chip low TC resistor with trimming.
U can make voltage and current references separately or u can make compact circuit.
    surianova
yes, thank you.i try already.. i found out it is quite ok to get constant current across power supply and temperature. But quite hard to get across process especially SS and FF.. i think that one might need trimmimg of resistors.
Hello surianova
you can refer this paper in the following site, maybe it is useful.
I am also designing a current reference with invariant for process and temperature.
I also think it is not very difficult for design a current reference with invariant for
temp and power supply.
Reference current
PTAT current+NTAT current
Consider I1=Vbe/R, I2=VT/R and then mix I1 and I2 with proper coefficients
Reference current
A ideal refrence current,;babbage
, Can the PTAT current+NTAT current realize it?
Reference current
Is there any good idea to make current reference with indenpendence of Temp and Process. all component should be on-chip. It is better to not use resistor, because it is too hard to make a precise resistor in silicon.
since its very low current and need stabilization for various parameter. u must use band gap reference to design design current mirror....
refer to sixth chapter in analog integrated circuit by ken martin
surianova said:
hi all!
chk if these can help you
  • cmos_current_ref_low_sensitivity_to_process_3937.pdf
    surianova
kumar123 said:
surianova said:
hi all!
thanks
Use a band gap reference circuit for your supply.
