What kind of circuit design is it?
Re: Circuit design
you check out this link... its about this cloc multiplier...
    ryusgnal
Re: Circuit design
This is a simple clock divider. In a D FF connect Q-bar to D input.
Re: Circuit design
its a clock multiplier...consult fsm design concepts....
Added after 5 minutes:
i think this circuit can be design using asynchronous fsm design techniques...
Circuit design
u should avoid using the clock generated from other signal in synchronous design
Circuit design
try exor gate where one input is clock and another is feedback from output with some delay. use buffer or even number inverters.
Added after 49 seconds:
for delay, use buffers or even number of inverters
