Help me to define the term "headroom" in analog design
tomph
Junior Member level 1
Could you please help me to define the term "headroom" in the analog design.
Is that votage swing limit before clipping ??
Tomph
Headroom
Headroom usually refers to the safety margin between a normal signal level and the clipping level. For example, "6dB of headroom" means the signal can grow to twice its normal amplitude before clipping occurs. It's similar to the 8 cm of headroom between the top of my head an a typical doorway - if I walk too lively, clipping will occur.
Re: Headroom
So when you clip, the strange noise you emit is the distortion? :D
Re: Headroom
Thank you for the lively analogy of "headroom" . I got it now.
-tomph
Re: Headroom
For example, if you want a MOS operated in saturation region and the vgs-vt=100mV, then the VDS needs to be larger than 100mV. The amount of VDS exceeding 100mV is called the headroom of this MOS.
Yibin.
Re: Headroom
Hi!
It typically refers to the output swings of the amplfiers. Suppose you are designing an amplifier and using a power supply: VDD=5V and VSS=0. This means that the 'theoratical' headroom you have is 5V. However this is almost impossible to achieve because transistors need to have a minimum voltage 'drop' across them to be in the 'proper' operating region. Hence the actual 'headroom' you get is lower than the power supply you use. The issue of headroom gets complicated in newer technologies for instance when you work with very low voltages (around 1V). The devices in these technologies have already poor characteristics (non-ideal effects and if you use techniques such as 'cascoding', then the headroom issue gets further complicated.
If you are novice to analog design, then you might not have understood many terms, never mind. For the sake of understanding, headroom can be defined as the maximum 'swing' you can acheive without landing into problems. Typically used term is hence the voltage headroom, which is the related to the maximum output voltage swing you can achieve without affecting the performance of the amplifier.
