ENOB and OSR ratio
yefj
Hello, In the lecture they say that if we double the OSR we get 0.5Bit increase.
I assumed its FOM of Walden as shown bellow but as you can see bellow We have 2^B goes down when Fs goes up so i cant see its happening.
Maybe they mean a different formula?
Where did i go wrong?
Thanks.
Maybe this will help -
Regards, Dana.
    yefj
If we don't oversample we have quantization noise power of LSB^2/12 which is distributed from 0 to Fs/2. If we keep the same FSR and physical bts out of the ADC but we sample twice as fast, that is the sampling frequency now is 2*Fs, then quantization noise power is distributed from 0 to Fs. If the signal BW is Fb, then now we will have 2x smaller Qnoise power in this BW compared to the case with no oversampling. So, Qnoise power drops by 3dB and since 1 bit is worth 6dB in Q noise power, then 3dB is worth half a bit.
Reactions: yefj
    yefj
Hello Sutapanaki, Yes i agree if we do the degital filtering on OSR=2 we qet SQNR ratio increase by 2 which is 3db so
ENOB=(SQNR_new-1.76)/6.02=(SQNR_old+3db-1.76)/6.02=enob_old+3/6.02
Is this the meaning?
Thanks.
factor of 2 (in voltage) is 6dB.
factor of 2 (in power ) is 3dB.
in my eyes:
* increase by two means " +2" (which can not expressed in dB)
* factor of 2 means " x 2 "
Reactions: yefj
    yefj
