intersecion problem objects coax and coax pin
Preeti Rani
Newbie level 3
hi, i am having a problem regarding hfss model that an error exists of intersection of objects coax and coax pin as shown in figure below.
and i dont find any way to stop this intersection between them.
i am having the coax of air and coax pin of pec material.could any one help me regarding this.
thanks and regard
Welcome Preeti Rani ,
The standard way to do this is to subtract the pin from the air. Be sure to check the "clone tool parts" before you do the subtraction.
Good Luck
ooooooooooooooooooooooooooo:(
Seriously, that's your first post?
Hi Preeti Rani!
I hope this file help you.It is a monopole antenna that is excited by a coaxial cable.
you can use from it's coax section.
*ghasem*
  • monopole_ghasem_sadeghi.zip
thanks and regard
preetiView attachment 97576[/QU
there is two method...
1st: go to HFSS>design setting > and click yes to override material...
2nd: subtract inner conductor with outer one ....don't forget cloning...
thank you so much for your help regarding my problem ..................................:):idea::grin:
