Antenna Violation in vlsi
aditya1579
All,
What is meant by an antenna violation ?
Thanks,
Aditya
check this link:
https://groups.google.com/forum/?fromgroups=#!searchin/vlsi-design-forum/antenna$20/vlsi-design-forum/6RQWVTQ_Sh0/fLkBDPwEpWsJ
During the Fabrication Process the large amount of charge is induced
in plasma etching, ion implantation and in other processes.
If a large interconnect (Poly or other Conducting material) is
connected to the Gate of a MOSFET, then this larger conducting
material will act as Antenna and will receive the induced charge of
the Fabrication Process.
The charge due to these extra carriers might be too much for the thin
gate to handle it, and it may also damage the thin oxide layer.
So, Antenna effect may result in breakdown of Gate Oxide or degrade
the I-V Characteristics.
To avoid the antenna effect we need to
1) avoid large Interconnect Area to Gate of a MOSFET by breaking down metal 1 to metal and metal 2 (see fig)
2) we can also use the diode placed near the MOSFET as in fig
Reactions: oratie
    oratie
